DE Prepped 2007 Cayman 2.7L
DE Prepped 2007 Cayman 2.7L 5 speed. Second owner.
18" S wheels, heated seats, auto climate control
Mods include:
-Vision Motorsports front BBK ( GT3 6 piston calipers & 350mm AP slotted rotors
-FVD deep sump
-TTP oil scavenge pump
-987 Motorsport AOS
-Softronics SRP & 4.1 flash
-Cayman R struts/springs
-TPC sway bars
-RSS front and rear LCAs
-Tarett bump steer toe links/drop links/front camber plates/rear strut mounts
-GT3 Master Cylinder
-3 QT Accusump in tunnel
-3 CSF Aluminum radiators
-GSR elect PS pump kit
-Fabspeed headers/sport cats/Maxflow exhaust
-CAE ultrashifter
-996 oil cooler and swirl pots
-Rennline gas pedal
-Odessy AGM battery
-BBi sport coil packs
-luggage barrier
-wheel studs
-fire extinguisher
-technobrace
-Rennline tie downs
Maintenance State:
DT40 OIL+FILTER 32697
REPLACE COOLANT 30973
REPLACE BRAKE FLUID 31847
REPLACE WIPER BLADES 29178
REPLACE TRANS AXLE FLUID 31847
REPLACE PS FLUID 29837
REPLACE ENGINE AIR FILTER 32006
REPLACE CABIN AIR FILTER 29178
WHEEL ALIGNMENT 30800
WAX 30314
REPLACE DRIVE BELT 29837
REPLACE TPMS 32855
REPLACE SPARK PLUGS 32045
REPLACE MANY COOLANT HOSES 23447
REPLACE FRONT TIRES 25847
REPLACE REAR TIRES 30392
REPLACE BATTERY 20700
REPLACE WATER PUMP 25123
REPLACE THERMOSTAT 21857
REPLACE COIL PACKS 27003
REPLACE HEADERS/SPORT CATS 27179
REPLACE AIR OIL SEP/MOTOR SPT 22870
SOFTRONICS PLENUM & FLASH 22870
REPLACE FRONT BRAKE PADS 29388
CLEAN MAF 32770
REPLACE RIGHT REAR TIRE 32855
REPLACE THREE RADIATORS/CSF 30973
List Date: 2/25/2015
For more info, click here to view the original listing: DE Prepped 2007 Cayman 2.7L
This item is no longer available.
