Porsche OEM 92-95 968-hvac Heater Control Valve 92857457303
that's the part in question (one of the valves has a vacuum leak causing the squeal)
---- found the part! ----
Okay, so this isn't a boost control at all...my googling was just awful...I google the electric controller thing and everything said booster control, but apparently that part is used for Air Injection Change Over Valve in the porsche - here's what my failing part is connected too....any ideas what it might be called? 08 Porsche Boxster 987 Air Injection Change Over Valve 99660512301
---- more updates! -----
https://www.youtube.com/watch?v=47E3-r6Gx8w here's the problem part pulled out
here's a photo if you'd rather not watch the video [image] https://photos.app.goo.gl/YtM2prWyXefSRZWy2 [/image]
It appears to be a vacuum regulator (maybe?) that is part of the boost control valve (pierburg pa6-gf30) anyone know what I can buy a replacement and how to replace it? It didn't seem obvious how to take it off without breaking anything
------latest update above-------
Here's a video showing the part that's squealing...I found it with a mechanics stethoscope (after a lot of poking around) and confirmed it was the problem child by wiggling it around to see if the noise changes (it does) - now my problem is I have no idea what that is so I'm hoping y'all can help me out there
https://www.youtube.com/watch?v=4N5ec_Eckd0
if I can make a new video giving you a better view of the part I'd be happy too - just let me know if I can help you help me
------------- OLD POST BELOW, RECENT UPDATES ABOVE ----------
edit: this is for a 2006 boxster s with 92k miles
edit2: here's the video highlighting the noises https://www.youtube.com/watch?v=Hlt-xelJ-xk
so I have a persistent squealing noise that I immediately thought I could diagnose by spraying silicone based lube on all the crankshaft pulleys (I think that's what I'm supposed to be lubing up?) but that didn't make it stop squealing so I dug further....the noise appears to be coming from the engine bay and not from anywhere close to the belt though so I googled around and everyone who had similar issues said it was the air/oil separator which made sense given the noise characteristics, but I replaced that and the noise is the exact same
so the noise characteristics are....upon cranking it's always quiet for about 10-15 seconds then it chirps a few times (really fast chirping) until it settles into a continuous high pitched squeal.....I can turn the car off and on a few times and sometimes the squeal never appears at all even if I drive it for a few minutes....the squeal only seems to change when I first accelerate
I've got some movement on one of my crankshaft pulleys so I'm thinking something might be failing there but I'm not 100% on which it is...it's basically the 2nd lowest crankshaft after the water pump
I'll post a video and hopefully catch the full range of audio for y'all tomorrow morning any tips would be appreciated
