I got tired of removing the trim at the seat belts, behind the seats and the rear hatch area to remove the carpet to access the aluminum engine cover for my yearly maintenance and to get easier access to the top of the engine. I purchased a carpet panel from the RL classifieds for $100 to cut and preserve my original carpet in case my plan did not work out and to restore it to it’s original condition.
I removed the original carpet by removing the plastic trim at the seatbelts and the aluminum grab bar and the adjacent plastic trim. I installed the new carpet panel by sliding it under the aluminum oil/coolant panel and the side trim. I then installed the plastic trim behind the seat but not the aluminum grab bar. I then marked the carpet with a sharpie using the plastic trim behind the seat as a guide. I removed the carpet and cut the carpet and foam 1/4” bigger than the marked line with a fully extended snap off blade.
I took the cut off piece and cut it into three segments so I could compress them and remove and reinstall them under the installed plastic trim to access the torx engine cover screws in the front corners. I did not use the two torx screws in the front center of the engine cover and left the center carpet segment in place and slide the aluminum engine cover under the carpet segment and all the remaining torx screws are easily accessible when the carpet panel is removed.
After reinstalling all the plastic trim and aluminum grab bar I can now remove the modified carpet panel in 12 seconds which gains access to the aluminum engine cover and can reinstall the carpet panel in 45 seconds if I leave the side edges on top of the trim and tuck it under the aluminum oil/ coolant panel and the plastic trim behind the seat. I can take the extra time and effort to tuck the carpet under the trim on the sides for a complete undetectable look but it isn’t necessary IMO. The hold downs are still functional. I have also reduced the chance of breaking clips from the removing of plastic trim.
Jim
Cut carpet panel on top of original carpet to show cut area which is 1/4” larger than marked line (to allow cut to be concealed under plastic trim. The narrow full width cut off section is then cut into three segments as shown installed below.
The cut carpet piece cut into 3 segments and compressed and installed under the plastic panel. The 2 corners are removable to access the corner torx screws.
Installed removable carpet panel.
When I travel or need extra storage I lay down a piece of DynaPad for extra sound control and use my Suncoast bag, which was also a fall back plan if I “screwed up” my removable carpet plan.😂
Jim
