1 - 10 of 10 Posts
Yes it does.
Should be in the same place as the slime; owner's manual has that info.
True for 987 (same compartment in frunk). Not for 981 (different compartments in frunk, side vs back).
BTW looks like the requirement of using a particular 12V socket has been dropped for the 981. In the 987.1 if you didn't use the cigarette lighter socket you would blow a fuse, adding insult to injury if you were stranded with a flat...
Reactions: Mike R.
The "slime" or tire sealant is located separately from the compressor in a small compartment on the left side (as you look into the frunk), or passenger side of the front luggage compartment.
Thanks madroadcyclist, your pictures were very helpful. So it is under the large cover that sits on top. The one that covers the shocks and runs from the front windshield to the frunk opening. Once removed it is in the front middle.
1 - 10 of 10 Posts
