This past weekend as part of my DE seasonal preparations I checked my coolant level. As you know if you've ever checked it, there's a "max" and "min" level mark, but unlike traditional coolant recovery tanks where you can actually see the level and can determine just how low it is, we'll only see that it's not at minimum, as mine was.
Since I've never seen a puddle, exhaust steam nor other evidence of a coolant loss, I thought it was probably a few oz down. To my surprise it took 40 oz of a 60/40 mix of Porsche's pink coolant to get to the min mark. Obviously my coolant was going somewhere it shouldn't.
My car went to my dealer today. They found 2 head gasket leaks, apparently from the water jacket to the outside of the engine where the coolant evaporated/burned away leaving nothing to drip onto the ground.
My car at 22k miles is the 3rd local, relatively low mileage, CS I know of that has had a similar head gasket failure. My '06 warranty is up this July so I'm glad it was caught under warranty. If you don't regularly check your COLD coolant level, I suggest you get in that habit. It's simple, takes a minute, but may catch a serious and expensive to repair reported problem such as a head gasket or water pump failure. Certainly you should have these components checked before your car warranty expires. Do NOT dismiss a need to add coolant as "normal."
