Looks nice, but I want to install the regular "metal" door pulls, and omit the "strap" entirely. Is that what you did,
because the pic is of a strap not a handle?
The part that is the most difficult (and it's really not that hard) is that the outer plastic panel that the straps fit into is heat molded onto the door card. Now, if you're careful, it can be dremeled away and replaced with screws. I've personally done it before but, here's the kicker: they don't sell that plastic panel part separately. They make you buy an entire new door panel!
Here is mine that I've drilled away the heat molding.
For you to do it at a reasonable cost, you'd need to find someone to remove and swap those panels (and other parts probably) with you that has removed them the same way so it can be reattached easily with screws. Oh, and they need to be panels that need to match whether you have saved seat memory buttons or not. So, find someone who wants straps instead of metal handles. Should be easy enough to find. I would even think local to you so you can compare door cards and make sure all the other parts will work.
Good luck and if you decide to attempt it Email me and I'll give more details on the screw attachment, etc.
I'm not a fan of the straps, if I had a choice I would go with a regular start that fits a standard Cayman. They are a feature talked about by all new passengers.
Related Threads
Planet-9 Porsche Forum
1.3M posts
62K members
Since 2005
Porsche Cayman Forum Boxster 911 Cayenne Panamera Macan Discussion powered by Porsche Enthusiasts Planet Wide!
