Curious if anyone has dealt with an issue like this previously. Did some searching and couldn't find anything exactly like this.
2007 Cayman @ 70k. Couple days ago, the "check engine / visit workshop" lamp came on. Gas tank was almost empty, thought it might be related to poor gas quality or a cap not fitted correctly. Turned out not to be the case. Stopped by a nearby Euro mechanic (not my primary Porsche only mechanic, but they seem like a really solid shop) to check the code. Turned out to be "System Too Lean Bank 1" which repeated a few times. The mechanic thought it might be a crankcase issue. Basically, the digital diagnostic tool had a checklist of possible issues he was going to check. I asked if it was safe to drive about 5 miles, he said yes, don't go far, and I took it home.
A couple things to note - there are no anomalies I could tell while driving. No vibration, loss of power, or horrifying noises. That said, right as I got a block away from home, I noticed when I slowed to a stop, there was a bit of a squealing noise that would only happen on deceleration. Not a brake noise. More like a belt noise. Wasn't sync'd to the brakes, per se, but definitely seemed to only happen during decel. Anyhow, parked it in the garage and now wondering if anyone has experienced this before, and if I should drive it back to the mechanic. Crankcase? Imminent AOS issue? Something else?
Sounds like a tow is worth the money to be safe (I don't have free tows right now, I know...) but just curious if anyone has thoughts on what this could be, or experienced anything like this. One other thing to add, every now and then I get the puff of white smoke on startup, which I hear is common with these models. But I'm not seeing billowing white smoke or anything like that.
