1 - 2 of 2 Posts
I have a 981 CS PDK fitted with Bilstein B16 Damptronic Coilovers and harder Eibach springs, my questions:
1. Does the DSC V2 work with Bilstein B16s?
2. Would I need a custom map set for this set-up, particularly would the harder springs affect the mapping?
And another question,
3. Do the GT4 offset toe links fit the 981CS and would they offer the same benefit? (I have RSS rear toe links fitted which allow for >2:00 degrees negative camber)
Many thanks for any info you can provide.
Porsche Prophet
Happy to answer your questions.
1. Yes DSC works with Bilstein B16s, as the factory shocks are made by Bilstein and the valve design is the same.
2. The B16s will not require a custom map, but you may feel as though customizing the maps offers additional improvement.
3. TPC Racing offers a rear toe link for the 981 that is similar in design, with the exception of the offset bushing. The offset bushing was designed specifically to combat the GT4's tendency to step out in the rear due to a large toe curve. The design may prove beneficial on other models as well, but we haven't tested it at this time.
1 - 2 of 2 Posts
