1 - 2 of 2 Posts
Cayman The Destroyer!
I had a very frustrating experience with my cable. The cable needs to be inserted just so to make contact and light the green LED. Even though the LED is illuminated I could not get any readings from the DME. I could see the other modules. the DME is on the KINE buss & the other stuff is on the CAN buss. I moved the cable around a little bit and managed to get contact for the DME buss. I'm going to try the connector pin bending as suggested by Scott and see if that helps.
I could not read the engine module for some reason. I get various errors when I try to read engine module and then the cable states the 3 car limitation and unable to proceed any further.
I have to recconect and start over but always skipping engine module!!!
1 - 2 of 2 Posts
