Fabspeed's Sport Catalytic Converters replace the restrictive factory cats with high-performance German-imported 200-cell HJS catalytic converters for significantly improved performance and sound. The Cayenne's factory cat-back exhaust has a very free flowing design when the valves are open so the only way to gain more sound and power is to change out the factory catalytic converters. HJS Sport Cats flow extremely well, flowing at 93 - 95% the rate of a straight pipe. Fabspeed Motorsport invested a lot of time and resources into developing the best possible downpipes and we're now proud to offer you this latest and greatest solution. Fabspeed Motorsport is the world's authority for aftermarket Lamborghini performance.
SOUND:
Aside from the factory catalytic converters, the E3 Cayenne GTS / Turbo has an extremely free flowing exhaust. So the best way to get more sound out of your Cayenne is to replace the factory catalytic converters. These Sport Cats will make your Cayenne sound much more aggressive. It really brings out the V8 sound from the 4.0L powerplant. Pops, bangs and crackles will be much louder and sharper. Best of all, there is no interior drone whatsoever.
POWER:
Get awesome bolt on power gains from your Cayenne GTS / Turbo with these Sport Cats. We saw max gains of 22 whp and 21 ft/lbs of torque. These Gains are carried throughout the entire RPM range for power you can feel in the seat of your pants. Peak power is also up 12 whp and 4 ft/lbs of torque!
FEATURES:
  • Fits all Porsche E3 Cayenne GTS / Turbo Vehichles (2019+)
  • The largest catalytic converter that will fit the application
  • German Imported HJS 200 Cell High Flow Catalytic Converters
  • Saves 6 lbs / 2.7 KGs compared to the factory Catalytic Converters
  • Adds 22 WHP and 21 ft/lbs of torque
  • The most effective Urus exhaust modification
  • No Check Engine Light Guaranteed
  • Constructed from mandrel bent T304L stainless steel
  • Simple DIY (Do-It-Yourself) bolt-on installation, no cutting or welding required
  • All Fabspeed performance products are backed by the Fabspeed Lifetime Warranty
(Sport Cats are model specific, results and description above are for the Cayenne GTS)
Cayenne GTS - https://www.fabspeed.com/fabspeed-po...nverters-2019/
Cayenne S - https://www.fabspeed.com/porsche-e3-...ic-converters/
