1 - 3 of 3 Posts
These are in good shape and have most of the material remaining, I used for a few autoX events.
9.67mm Pad material remaining when measured with a digital caliper
$40 shipped
Product Information
The EBC YellowStuff compound is essentially a race pad but with a big difference in that it works from cold and can be safely used on the highway. If you want the ultimate in high friction braking this is the pad to choose. Brakes feel superb from first touch of the pedal and stay effective up to race temperatures. EBC YellowStuff is designed for faster imports and muscle cars where maximum stopping is prime requirement and for short duration track use. The dust rating is similar to OEM parts. All pads come with edge chamfers, center line slots, noise reduction shims and OEM hardware as needed. All EBC pads feature the EBC Brake-in surface coating which helps pads seat quickly after install.
Specifications
High friction pad for better high speed stopping
Zero fade race developed compound
Brakes effective right from cold
Can be used on street or race track
Part#: DP41208R
Product: Yellowstuff Street And Track
Position: Rear; Pad Set
For: (2007 - 2012) PORSCHE BOXSTER S H6 - 3.4L
1 - 3 of 3 Posts
