2006 CS, 22Kmi, manual shift, HR springs, stock 19" wheels. I purchased the car used and don’t have a ton of experience driving it so I don’t know if it is just me but if i am going 45mph in fourth gear and stab the gas, the front end will lunge to the left then come back to strait. Same thing if I let off the gas, it will lunge to the right. I just used 45mph and 4th as an example. It will happen in any gear and really "upsets" the car...any ideas? it is sort of like the *** wiggles, but a lot. I would guess 3 degrees of heading change when you initially hit the gas from holding a steady speed. The tires defiantly do not break loose, and it does this Every time.
