Does anybody have the resistance vs temp curves? All I really need is a resistance that will give me reasonable operating range.
This is to fool the factory ECU that the engine is healthy and to run the AC compressor. Motec runs the engine, and right now AC.... but I am considering letting the factory ecu handle the compressor as it will likely be more simple thanhacking the canbus enough to see things like AC pressure, evap temp and AC control position. usually it ends up being bi directional which can be hard to solve.
