Available for pickup in the San Francisco area.
I have 3 wheels from a very nice set of RH alloy wheels from a 996 that go for over $3,000 for a set. For someone who either has these and could use a spare, or is willing to pick up the matching front wheel from GMP Performance or RH-Rims.com.
The RH MK-19 wheel is a German-Made, TUV Approved, three-piece modular wheel with a cast center and spun aluminum inner and outer barrels. The wheels accept factory mounting hardware and center caps so you can install them with your original lugnuts as well as your factory center cap. The wheel also features a hub-centric 71.6mm centerbore to ensure a bolt-on smooth ride without the need of any additional hub-centering rings.
Fronts are 19 x 8.5, 50 offset, 5 x 130 bolt pattern
Rears are 19 x 10.5, 62 offset, 5 x 130 bolt pattern
