Let’s see what you have
I believe the GTS is an original, but will have the dealership confirm if it is a factory GTS piece and then I will know how to remove it and attach the factory spoiler.A lot of these new lips that are not real Aggressive just use 3M tape… you could tap into both and use the oem push pins….how was the GTS attached??
Believe it or not tape is enough.
its probably tape… heat it up with heat gun or blow dryer and run a piece of fishing line or a guitar string in between the two and see if it separates them..I believe the GTS is an original, but will have the dealership confirm if it is a factory GTS piece and then I will know how to remove it and attach the factory spoiler.
