Hi there:
I recently had a set of Eibach springs installed on my 2007 Cayman S. When I brought them into the shop that did the work they advised me that they have had issue with Eibachs making noise and they would rather sell me a set of H&Rs.
I stuck with Eibachs as I liked their spring rates better.
I have a strut brace installed in the car, and Eibach springs were installed with stacked Porsche compensating plates - 3mm and 6.5mm.
Well they do squeak right at the point where the suspension is getting slightly loaded or unloaded - braking (slowing down) or getting off the brake. This can be reproduced when you press on the fender or step in the trunk with one leg and press down ~50 lbs. This goes away in dry weather and gets worse in damp. I live in Seattle.
I assumed that the noise was coming from the stacked compensating plates and after much wrangling last night I removed them. I also checked the strut brace and can not make it rattle or make any noise by pushing on it. The noise does appear to be coming lower - where the springs are.
Well, removing compensating plates did nothing.
My theories:
What do you think?
Tomasz
My theories:
- In proper install where some of the bushings were not tightened with the suspension loaded and its the bushings that are making the noise.
- Eibachs are making the noise. Specifically, the dead area of the spring or spring helper area that is 100% compressed with the car on the ground where the coils touch - stack on themselves is covered with a rubber sleeve. That rubber is making squeaking noise as the coils stack and un-stack.
What do you think?
- What bolts should I undo and re tighten properly?
- Should I cut off some of that rubber? Is any of it needed? I guess metal to metal contact is not advised.
Tomasz
