Wheel spacers make your tires and wheels appear wider by moving the wheel out from the hub, providing both performance and appearance improvements. Whether you want improved handling, increase safety, or simply desire your car to make a statement about your individual style, wheel spacers can help you accomplish your goal.
FVD Brombacher Germany conveniently combines Porsche specific H&R spacers, the correct Porsche bolt shoulders and the correct length H&R bolts to take the guess work out of adding spacers to your car. Our spacers are cost competitive and have been developed to work together without compromise. Don't be fooled by the competition whose costs quickly add up by requiring you to order the spacers, bolts and bolt shoulders separately. Also, H&R Spezialfedern GmbH & Co. KG (H&R Springs) is an OEM supplier to Porsche, so why spend more for Genuine Porsche spacer kits, or risk wheel vibration with a lesser brand?
Features:
  • Includes Proper Porsche Wheel Bolt Shoulders / Ball Seat
  • Made in Germany for FVD Brombacher by H&R Spezialfedern GmbH & Co. KG (H&R Springs)
  • Can be used in front and/or rear
  • Size / Thickness: 7mm/11mm/15mm/18mm/23mm
  • Bolt Pattern: 5/130
  • Center Bore: 71.6
  • Bolt / Stud: Bolt
  • Thread Type: 14x1.5
  • Material: Strength Tested Aluminum Alloy
  • Coating: Anodized for Corrosion Protection
Sold individually. 2 necessary per axle.
Please Note: If you have over-sized (non-factory) wheels, please consult a wheel specialist for size requirements before purchasing. Not compatible with center-locking wheel systems! Wheel lug bolts should always be removed by hand, preferably with a soft socket which will not scratch or chip the anodized surface (please don't use an impact wrench or gun). Lug bolt installation requires torqueing to the manufacturer's specifications listed in the manual.
For more Details, Please check out our website here...
If you have any questions on this bar or any of our products, feel free to contact me via email or private message.
FVD Brombacher – USA
Theo Brombacher
Email: [email protected]
Visit the WORLDS LARGEST Porsche Online Shop at www.fvd.net for over 45,000 parts!!
