<h5>2007 Porsche Cayman</h5>
<div>Porsche Reneges on its word and makes a Cayman, No 'S'</div>
<div>by Natalie Neff</div>
<div>AutoWeek | <span class="updatedStamp">Published 08/17/06, 3:31 pm et[/quote]</div>
Cayman, the Car, is a reality. Introduction. The story is familiar, the car is brilliant.
<table cellspacing="0" cellpadding="0" width="100%">
<tbody>
<tr>
<td class="subsection">AT A GLANCE:</td>
</tr>
<tr>
<td>
<table cellspacing="0" cellpadding="0" width="140" align="right">
<tbody>
<tr>
<td width="1" bgcolor="#000000">
</td>
<td align="right" width="139">
<span class="moreRed_11">>> PHOTO GALLERY >>[/quote] </td>
</tr>
</tbody>
</table>
<span class="black_14_b">2007 PORSCHE CAYMAN[/quote]
ON SALE: Now
BASE PRICE: $50,195
POWERTRAIN: 2.7-liter, 245-hp, 201-lb-ft H6; rwd, five-speed manual
CURB WEIGHT: 2867 lbs (est.)
0 TO 62 MPH: 6.1 seconds (mfr.)
FUEL MILEAGE (Combined): 25.3 mpg (est.)</td>
</tr>
</tbody>
</table>
Photo Gallery
<span id="intelliTXT">Perhaps there was a misunderstanding. Perhaps when Porsche insisted the Boxster S-based coupe would be the lowest-powered and lowest-priced model to carry the ’gator badge, something got lost in translation. Perhaps when we heard “Nie!” what Porsche really said was “Oui!”
Then again, perhaps not.
No one seriously believed Porsche anyway. Not when it offers a dozen or so variations on the 911 theme from which to choose, as well as four takes (and counting) on its Cayenne sport/ute. So why would anyone buy into the preposterous notion that Porsche would release just a single version of the Cayman coupe? Fact is, few folks ’round these parts would flinch if Porsche followed the rollout of the standard Cayman with a Cayman Turbo, Cayman Club Sport, Cayman 4S, Cayman convertible...
Okay, that would be weird—but not entirely unimaginable. But we digress.
No matter who said or heard what at the outset, Cayman is a reality. Evidence to that end extends beyond the pictures on these pages, too: Stop by your friendly Porsche dealer and you will surely encounter a couple non-S Caymans for yourself.
If you know anything at all about the journey from Boxster S to Cayman S—or about the standard Boxster itself—then the Cayman’s story should sound familiar.[/quote]
<span>
<table cellspacing="0" cellpadding="0" width="490" border="0">
<tbody>
<tr>
<td class="black_11" style="PADDING-RIGHT: 0px; PADDING-LEFT: 2px; PADDING-BOTTOM: 10px; PADDING-TOP: 0px">
<table cellspacing="0" cellpadding="0" align="right" border="0">
<tbody>
<tr>
<td style="PADDING-LEFT: 10px">
<div align="right"></div>
</td>
</tr>
</tbody>
</table>
</td>
</tr>
</tbody>
</table>
[/quote]
<span>The majority of the powertrain and chassis components that make the roadster a little piece of driving nirvana find their way into the coupe nearly wholesale. An improved-for-2007 version of the current Boxster’s 2.7-liter flat-six pumps out 245 hp and 201 lb-ft of torque, up 5 and 3, respectively. Those increases come courtesy of Porsche’s VarioCam Plus on the intake side, which adjusts valve timing and stroke to optimize engine performance at any rev point (the 2007 Boxster receives the same engine, whereas the previous model settled for plain ol’ VarioCam without the variable lift feature provided by the Plus).
The 2.7 also borrows the intake manifold from the Cayman S’s 3.4-liter engine (now also used in the Boxster S), with its resonance and distributor flaps and double-chamber distributor pipe. At lower speeds the flaps remain closed, essentially turning the engine into two three-cylinder motors. This helps to maximize torque across a wide swathe of the rev range, with peak torque available from 4600 to 6000 rpm.
The engine also sees a slight increase in compression, from 11.0:1 to 11.3:1, which contributes to the higher output. Yet some of that apparent advantage is gobbled up by the car’s additional heft at the curb—a whopping 12 pounds of extra mass, at an estimated 2867 pounds, compared to the Boxster.
A five-speed manual transmission comes tied to the engine standard, though the same optional gearboxes as found on the Cayman S exist here as well: a five-speed Tiptronic automatic with steering wheel shift buttons, and a top-notch six-speed manual. Opt for the six-speed and Porsche throws in Porsche Active Suspension Management, which adjusts damping rates depending on driving conditions. Not to be confused with Porsche Stability Management, or PSM, which comes standard on the Cayman (and incorporates antilock brakes, brake force distribution, and traction and stability control functions), PASM allows the driver to select a particular level of suspension damping, from Normal to Sport, by simply pressing a button.[/quote]
<span>
<tbody>
<tr>
<td style="PADDING-RIGHT: 0px; PADDING-LEFT: 0px; PADDING-BOTTOM: 10px; PADDING-TOP: 10px">
<tbody>
<tr>
<tbody>
<tr>
</td>
</tr>
</tbody>
</table>
</td>
</tr>
</tbody>
</table>
</td>
</tr>
</tbody>
</table>
[/quote]
<span>The most aggressive driving setup can be had by selecting the optional Sports Chrono Package, which raises the thresholds for PSM intervention and increases the throttle response. It delivers the most track-worthy PASM setting as well.
Porsche says Cayman will reach 62 mph from a standstill in 6.1 seconds, with a top speed of 162 mph. From a seat-of-the-pants perspective, the Cayman we drove felt every bit as quick off the line as claimed, if not quicker. We don’t have to take Porsche’s word regarding that top end, however. That we can vouch for—with the help of a glorious invention called the autobahn.
At well into triple-digit range, the Cayman feels as stable as it does at more typically American cruising speeds. Getting up to speed, however, is arguably the best aspect of the overall Cayman experience, the six-speed manual making easy work of keeping the car moving through the fat part of the 2.7’s torque band. Throws are short and precise; never once did the shifter hang up between gates during even the most aggressive shifting maneuvers.
Likewise, the clutch pedal syncs perfectly with the shifter’s action, with decent weight underfoot and a take-up point in the sweet spot of pedal travel. The bonus to all that shifting is the associated soundtrack—a symphony of engine and exhaust notes delivering a feast for the ear to rival the best even the Cayman’s optional Bose stereo can offer.
The car carries over the tire offerings from both the Boxster and Cayman S as well, with the Boxster’s 205/55 front and 235/50 rear Z-rated 17-inch rubber coming standard. Our test vehicle came shod in the optional 18s; at 235/50 front and 265/40 rear, the tires are a nice match to the car’s setup, with a ride far from soft but nowhere near punishing, as the top-line 19-inch optional tires can sometimes be.[/quote]
<span>
<tbody>
<tr>
<tbody>
<tr>
<tbody>
<tr>
</td>
</tr>
</tbody>
</table>
</td>
</tr>
</tbody>
</table>
</td>
</tr>
</tbody>
</table>
Slowing from autobahn speeds feels just as impressive as reaching them, the Cayman’s vented and cross-drilled brake discs—slightly smaller than those found on the Cayman S—doing a fantastic job of erasing momentum in a hurry, and with a satisfyingly firm pedal feel.
While the Cayman’s steering offers confident, straight-line operation on the autobahn, it’s off highway where the brilliant feel of the road shines through, with a reflexive turn-in action and zero dead space on center. Pounding around mountain passes poses a much bigger challenge for the nerves than for the car, as the Cayman forgives even the most boneheaded moves. Blasting into a turn way too hot, lifting abruptly midway through, gripping the wheel tightly while lessons learned from Porsches past fill your head (“Don’t lift! Never lift!”), and... nothing. There’s no snap oversteer, no spinning, no ricocheting off cliff walls and especially no plummeting to an untimely death. The car does, however, shift weight forward in a most placable manner, the nose tucks in neatly and—voila!—the car turns.
Porsche didn’t fret too much over trying to distinguish the Cayman from the S version. Visual differentiators are limited to black brake calipers, black front-spoiler lips, a single squared-off tailpipe and a black-faced instrument panel.
Plans for the 2006-07 sales year at Porsche call for a total of 15,000 Cayman and Cayman S sales worldwide, with roughly half that making their way Stateside. Stickers start at $49,400, with the $795 delivery charge sending the base Cayman over the $50k mark—and slotting directly above the more complicated-to-build Boxster convertible and its $45,600 price tag. That would strike us as a weird move from most manufacturers, but this is Porsche.
[/quote]
Edited by - mpollard on 08/22/2006 11:23:19 AM
Is this an accurate statement? 'Perhaps when Porsche insisted the Boxster-S-based coupe would be the lowest-powered and lowest-priced model to carry the 'gator-badge...''
When I first became interested in the Cayman S in January, it seemed clear from everything I read (and was told by several dealers) that there would be a Cayman in the near future at about $50K. And so there is. Perhaps there were such statements by Porsche in prior years, when the Cayman (S or not) was still in the planning stages. Or is this just another mis-informed journalist out to further bewilder poor little me (who is already dazed and confused about plenty of issues even beyond the nature of Porsche's mid-engine coupe).
I've alwayswondered how the base Cayman would have been receivedif Porsche had released it prior to the S. I've always find it odd that Porsche chose to introduce the more powerful version first.
To me, it's counter intuitive...but then again, as writer had mentioned, 'this is Porsche'.
Edited by - TurboFlat4 on 08/22/2006 12:07:13 PM
