I'm in the same boat. Catching up on a bit of maintenance and getting the car track ready. I'm going to do what I can to keep the M97 happy and healthy. I've got quite a few more miles than the original poster (95,000). Purchased a year ago at 91,000 miles.
So far I've done a brake overhaul (pads, fluid, lines, new rear rotors). Put in a new battery and AOS (OEM, not the fancy sport model just yet), and a fresh air filter and cabin air filter.
I've bought 2 sets of wheels, and 3 sets of tires (18" summer/ Michelin Pilot Super Sport), (19" all season/Conti DSW06 Plus), (19" autocross/Bridgestone RE71RS).
I am hoping to get a performance alignment done soon. I'm trying to track down some specs to give the shop as a target. I am on stock suspension (PASM), with the exception of GT3 top hats in the front.
I would like to add some sway bars and more adjustability in the future.
I just received a new water pump, lower temperature thermostat, and serpentine belt. I've got a LN engineering 2qt deep sump oil pan and skid plate on the way. I will be doing an oil change with Driven DT40 oil. I would consider Motul once I am ready to do track days next year. I'm thinking that DT40 should be good enough for autocross and street use.
I will be changing out the gear oil soon as well. Leaning towards using Motul 300 75/90. I'm sure that it hasn't been changed in quite a while. The car has a Quaife LSD added, Quaife states that using the factory spec gear oil is sufficient.
The shifter cables will need to be changed soon as well. I'm hoping that I can hold off on those for a little while by shifting a bit gently. I'm also considering a short shifter at the same time.
The shift feel is by far my least favorite part of the car. I'm hoping that the fresh gear oil is a good start.
I'm thinking of getting the main hose that connects to the water pump, as well as possibly the serpentine belt tensioner to do at the same time as the water pump. The original poster had a tensioner go out at 1/3 the amount of miles that I am at. Is this a common issue or was that a bit out of the ordinary.
If you guys see any maintainance items to do with the water pump/belt system that I am missing let me know. I'm hoping to get all of the easier not too expensive stuff done all in one shot.
