1 - 12 of 12 Posts
My 2009 Carrera White Cayman S was next to a 2006 Carrera White CS at a recent service clinic under floresent lights. The color of the cars was noticably different. 2006 was a mellower white (kind of a yellow base), 2009 had more of a blue look. The owner of the '06 asked if mine was Arctic White. When I got home I checked the window sticker just to make sure it wasn't! Did Porsche change the color?
Super Moderator
I'm somewhat unclear on what happened. The color is supposed to be "CARRARA White". Were you next to a Carrera (911)?
Porscheholic
The guys are just having fun - slow Tuesday. Carrara White is a standard paint choice for 2006 - 2010. Cream White is an Option which looks more yellow-ish.
I would look at the cars outside in sunlight. Depending on if the flourescent lights were installed at different or same time or similar wattage - they cast varying shades of flourescent. But probably too late by now.
Or.. it's just the paint aging on the older car...
My 06 is carrara white, but i can already see under certain light conditions that the plastic pieces are yellower than the metal body parts... Particularly the roof rack trim... It's subtle, but it's there. I bet your car is bluer because it's newer ! ;)
Sexual Philanthropist
Also, different batches of paint, applied in different facilities under different conditions years apart. You should see some of the variations in Lotus paint.
Same with me, my 2008 Carrara white shows yellowish at the roof rack inserts only.
This is probably the case. It's likely that the clear coat has yellowed in time from that nasty sun.
As an aside, if it is localised discoloration it may be that these are painted plastic trims. I haven't looked at mine in detail, but I'm pretty sure the insets for the roof rack are painted plastic. These are known to have their problems of course. I had paint 'failure' on my Audi S3 on the painted front bumber, the paint literaly flaked away on touch....
1 - 12 of 12 Posts
