1 - 13 of 13 Posts
Alright 987 guys listen up... When you own the cars and have used the products, you can truly give the best advice and direction for what products to buy. For you Porsche fanatics buried in the snow, track season is upon us and it is time to get serious this year with improved braking. You are only as fast as you can stop. The further you dive into turns, the faster you come out. The only brake choice should be Brembo, and that is evident by the numerous professional racing teams that use Brembo and pay for their Brembo brake products.
Vivid Racing is one of the largest Brembo brake dealers in the USA, proven fact. We stock all Porsche applications for same day shipping in all the available options. So what is available for the Porsche 987 Cayman or Boxster and why should you run a Brembo Brake Kit?
All Brembo big brake kits include street pads, steel braided brake lines, 2 piece floating rotors with patented McLaren hardware, calipers, brackets, and ONLY at Vivid Racing, Brembo brake fluid. Now for you guys that are going to do some track racing, get rid of those street pads and Vivid Racing can substitute them for track pads from Porterfield, Ferodo, or Pagid on the 4 and 6piston calipers. The same engineering that goes into the race team brakes and the OEM brakes found on the Porsche can be equated to what is on these GT kits. The patented McLaren hardware is only used on Brembo kits and this allows the rotor to have a true center line for better pad wear, improved heat dissipation, and overall longer rotor life. The increased veined rotors also help tremendously reduce brake fade. Each 355mm rotor saves about 7lbs of rotational weight per corner on the Porsche. Other companies try to replicate the hardware with a nut and bolt. This does have the weight reduction of a 2pc rotor, but because it is not a "true floating" design, this causes the aluminum brake hat to become a consumable item. Brembo rotors last about 3 times longer then OEM and 2 times longer then its competitors. Many PCCB owners will switch to the Brembo setup for further improved braking and longer rotor life.
When engineering Brembo's calipers, they take into account the use of the OEM rear brakes and design the piston bore to be specific for that cars braking bias, weight, and overall needs. For the Porsche Turbo, the front 6piston kit is a monoblock design to improve rigidity over the stock caliper for a more responsive pedal feel. The kit is available in a 355mm, 365mm, or 380mm rotor. The 6 piston caliper weighs only 1lb more then the stock 4piston design. It is not required to get the rear kit, but will improve braking performance overall.
All Brembo kits are available in red, silver, black, or yellow calipers. We can do custom colors at $400 per axle. Rotors are available in your choice of drilled or slotted. We recommend slotted for the track guys.
Brembo Front 355mm 4 Piston Brake Kit 2pc Porsche 987 - CALL FOR PRICE
Brembo Front 355mm 6 Piston Brake Kit 2pc Porsche 987 - CALL FOR PRICE
Brembo Front 365mm 4 Piston Brake Kit 2pc Porsche 987 - CALL FOR PRICE
Brembo Front 380mm 6 Piston Brake Kit 2pc Porsche 987 - CALL FOR PRICE *Requires 19" Wheels
Brembo Rear 345mm 4 Piston Brake Kit 2pc Porsche 987 - CALL FOR PRICE
View all photos here - http://www.vividracing.com/forums/gallery/browseimages.php?c=432&userid=
[photo removed pending approval]
Now for those HARDCORE Track Guys, you need the custom spec GTR Racing Brake Kit.
With all the same advantages of the GT kit, the GTR kit is custom built to your needs and specifications. You get the equivalent of a full race team brake kit without the maintenance needed. he nickle plating is inspired by what F1 race teams use and the calipers are 10% lighter then the current Monobloc calipers on the market. They are much stiffer, provide better pedal modulation. The NEW line of GT-R calipers were designed to provide every level of performance as these top level race calipers, but with superior plating for aesthetic longevity and corrosion resistance’s, and incorporate a twin seal design that eliminates the need for the additional maintenance of rebuilding. A simple set of caliper temp stickers, (also available through Vivid Racing) is all you need to ensure you are running within optimal operating temperatures during the most aggressive track outings. Thus Brembo has released a GT-R kit that is street friendly and ready for the serious racer.
Brembo Front 6piston 355mm 2pc Rotor GTR Brake Kit Porsche 987 - Call for Pricing
Brembo Rear 4piston 345mm 2pc Rotor GTR Brake Kit Porsche 987 - Call for Pricing
Brakes, who needs brakes? They only slow you down!
Many different race pads are available. I guess we would need to discuss your setup, tracks you run, and more.
The factory are a 4piston brembo caliper. The Brembo upgrade kits are available in 4 and 6piston monoblock calipers. The largest benefit of their 4piston kit is going to the lighter 2pc rotor. This rotor as explained gives better pad wear with a true center line, better braking with the increased vein rotor, and better heat dissipation. Keeping this 4piston caliper and using the bigger rotor also gives you better pedal modulation. Going to the 6piston caliper is a whole new world of better braking.
And both options look SWEET
Can the brembo slotted rotors fit the stock calipers?? Do they use same pads?? What about using them with Pagids??
Just FYI the factory brakes are Brembos
Yeah, I agree. Aren't Porsche OEM brakes already amazing? This topic title makes it sound like our stock brakes suck or something. I don't like it. Also, if I wanted REAL braking I think I'd go with something from this manufacturer.
It might be nicer to promote your product without trashing our existing set-up.
:cheers:
"Many PCCB owners will switch to the Brembo setup for further improved braking and longer rotor life."
Only if your insane!
1 - 13 of 13 Posts
