Today I replaced the rear rotors on my 987.2 mostly track car with a set of 325mm Girodiscs. I had done the fronts earlier in the year and was really impressed with the difference they made, both in braking force and heat management. And they appear to be handling the Performance Friction 08 pads nicely, showing little wear or scoring after several tough days at the track.
Although I knew the rears were in sad shape, only when I pulled them off and took a close look did I realize just how far gone they were. Each disc had the usual cracks emanating from the holes, but each also has a crack that went all the way to the edge and on through the disc surface. Nasty, and potentially catastrophic, if the discs decided to shatter at speed during heavy braking.
Now the car has proper brakes at all four corners, and once again all is right in the universe.
