1 - 2 of 2 Posts
Girodisk rotors
Used Girodisk rotors/hats from 2014 981CS. Front rotor is for upgraded 991S 6-piston caliper (see http://www.girodisc.com/Girodisc-Front-350mm-2-piece-Rotor-Upgrade-for-Porsche-991-C4SC2S_p_6517.html). Rears are designed for stock 981CS (see http://www.girodisc.com/Girodisc-Rear-325mm-2-piece-Rotor-Upgrade-for-981-Porsche-Bosxter-SCayman-S_p_6571.html). The front rotor will need to be replaced, since it is at 31.97mm and the minimum spec is 32mm. The rears are at 19.5mm, with a minimum spec of 18mm, so they still have plenty of life. The Girodisk is a floating two piece rotor, so you retain the hats, and only replace the rotors. If you send them back to Girodisk, they will do the exchange for you. If you have the hat, the front replacement cost is $800 instead of $1,200 new. The rears are $700 instead of $1,100. Asking $500 or best offer. Would prefer local pickup, but will ship.
List Date: 1/2/2015
For more info, click here to view the original listing: Girodisk rotors
This item is no longer available.
1 - 2 of 2 Posts
