I started my car this afternoon and immediately got the red warning that my driver's side rear tire lost pressure, -15 PSI. So it's going to be one of those days. Quick inspection after rolling the car out of the garage revealed a screw head sticking out smack in the middle of the tire. Nowhere near the side walls, fortunately.
Given that the pressure difference was already down to -19PSI after my quick inspection, I carefully drove the car the rather short distance to the nearest mechanic, because I did not want the tire to go so flat that I would have had to call a towing company or something. They repaired the tire immediately, within 15 or 20 minutes or so, and I was on my way back home.
So now my question is... can I keep it like that? Might the at least -20PSI pressure difference once I reached the mechanic possibly have damaged my tire? Is the quick repair likely to be sufficient, or will I have worse problems down the road (no pun intended)?
