2016 Cayman GT4
I am looking for the location of the main fuse box, the one with the big 100 amp and 40 amp fuses. I have the circuit diagrams.The wiring diagram has it somewhere around the front of the drivers door or under the dash. I don't have power to the cigarette lighters or the seat height adjusters and they are all fed from a 40amp fuse at M1. Trouble is I cant work out where the main fuse box is located is it up under the dash somewhere? I found an image but still cant find it
https://autoparts.beforward.jp/detai...es/PA28715282/
It is located in the left footwell, behind the aluminum panel that contains the OBD2 connection.
2016 Cayman GT4
Discussion Starter #4 (Edited)
That worked, passenger side footwell (RHD), up against the lower firewall, it is huge. Now to wrestle it loose, get to the other side and change the fuse. I removed the triangular cover and the fuse at M1 does not have power on the other side. Will be interesting to see if it is loose or blown.
267671
