1 - 3 of 3 Posts
Does anyone know if the H&R front spacers (0.7 cm) for a cayman s with 19 " rims are double-centering? Or otherwise not necessary because the hub of the wheel with this thickness of 0.7 continues to provide support?
:thanks:
The hub is thicker than the spacer and leaves enough lip to center the rim. I have H&R on my car and they are very high quality.
Thank you very much Andre, I already have installed H & R spacers of 1.8 cm at the back and now I will put in front 0.7cm spacers and so wondered if need twice as centering or otherwise not needed because the hub the tire is enough.
Thank you very much.
1 - 3 of 3 Posts
