1 - 13 of 13 Posts
I put a set of RSS sway bars on my car recently and am very happy with the results. Flatter cornering attitude, sharper feeling steering response and no affect on the ride. Haven't been back to a track event yet but I'm very happy with the road handling. Apparently the H&R bars are slightly larger in outside diameter than stock so the installation is a little trickier where the RSS bars are the same diameter so there are no fitment issues at all. All the bars are hollow, the RSS have thicker sidewalls for greater stiffness than stock (same for H&R).
Talk with Tom at Rennsport One, he sells both brands and gives a fair evaluation of both.
BW
Tennessee Vol
BW
My CS is in shop today for RSS bars and links. Will post later with track results.
Tennessee Vol
I put a set of RSS sway bars on my car recently and am very happy with the results. BW
BW,
What setting (which hole) did you use on the bars?
Thanks
Can anyone comment on using the stock drop links with the H&R bars? I got some Tarret Engineering rear links, but haven't put the bars or links in as yet. To avoid oversteer, I plan to put only the rear bars in at first set on the less stiff or outermost hole position. I was worried that the Tarret links would be noisy, and that the stock links would be weaker and softer.
981CaymanS
Gasmang;
I installed the H&R bars almost three years ago with the stock links and never had an issue, I love them.
However, I would recommend installing both bars at the same time and adjust the rear to fine tune your balance, I think you will like them.
BTW I like to use 34psi front and 37psi rear and the hardest setting on the rear for a really crisp response.
Thanks for the news about the stock links. My H&R bars were modified so that the front bar has an extension with an extra hole for a softer front setting.
MDavis,
I have mine in the middle holes front and rear to start. I'm waiting for a track day to decide on any changes from there.
Casey,
Thanks for the correction.
BW
Tennessee Vol
Re: mdavis
how hard are these to install ? thanks
Looks like it will take my guy about three hours to do front and rear. I pick up the car today and will let you know.
1 - 13 of 13 Posts
