Has anyone done any braking measurement tests?
1 reading
6.4K views 23 replies 13 participants last post by  gtscayman
#1 ·
Yesterday in preparation for a new rotor install I decided to go out with a friend and record my stopping distances from 60mph on repeated runs to get a range of distances as a "Before" sample which I will later compare to the after test that I will run after the new rotors and pads are installed.
I was wondering if anyone else has done any braking tests and if so what distances you achieved from what mph. If anyone else wants to run some 60-0 tests and let me know what they are I'd appreciate some extra data points for comparison.
Thanks!
#5 ·
I think it will be too hard to get repeatable 60-0 measurements. IIRC, my G-meter will only give me 60-0 if it gets a 0-60 first, and there's just not a whole lot of places where I can do that. What is fairly repeatable is peak Gs braking. You can also experiment with different levels of threshhold braking versus the number of wheels of ABS. By far, the biggest difference you will encounter is differences in tire compound, road/tread temperature, etc. For example, I regularly use the "Gs to ABS" as an indicator of how much traction I have, particularly as the temps drop and/or the tires are cold.
I had a decent brake thread on 6-Speed which I need to update and repost here. Just too much else going on. To summarize, there are some really nice gains to be made by shifting brake bias. Most other changes only solve heat-soak problems. Beyond that, tires are the main limitation.
#9 ·
Re: Okay.
I was actually thinking distances because my 60-0 stopping distances seem remarkably short as compared to the published 70-0 stopping distances. The Girodisc article has my numbers in it.
The extra 10mph makes a big difference, as I am sure you know.
#10 ·
Re: Okay.
Yes, but I am surprised that the extra 10mph would move the numbers from say 70feet to 106ft, in other words 36ft more or 1/2 the distance again just for another 10mph. We ran multiple runs, we tested and measured multiple times so I have to believe our numbers are accurate, but I also think I can beat the magazine numbers for stopping distance from 70. :) Maybe, maybe not...
#11 ·
Re: Okay.
I think the distances should vary like the square of the speed, so a 70 mph distance would be (70/60)**2 = 1.36 times larger than the 60 mph distance.
Neglecting reaction time, of course.
#21 ·
Re: Okay.
ABS cuts in to early as it is with my new standard disks and rs42 pads.
I can cut mine in easy at 60Mph so bigger pads and disks are not going to help 60-0 runs one bit. I already have to cadance brake to beat the ABS systems distance.
pointless doing test without a good GPS meter, mine can do 60-0 without doing any 0-60 stuff.
to see any real gains with bigger disks you will have to test from 100Mph or test 5 times in a row from 60Mph and mesure the last one where fade might cut in with a standard set up.
But for 1 off 60-0 distance only your right foot is going to better times/distance.
#23 ·
Re: Okay.
As a point of note I didn't do a "one off" test, before changing disks we did probably 10 runs from 60-0 and measured each one and they all fell within an 8ft range. After the install we did the same number of runs and again everything fell within an 8ft range but this time the range was 4ft shorter (went from 70-78 to 66-74). I said elsewhere either my neighbor mismeasured the distance with the tape measure or suddenly my speedometer is so far out of whack it doesn't seem possible since I can compare it to GPS as well as the GPS in my radar detector any time it goes off my speedometer is never more than 1 or 2 mph off at most and usually it is either dead-on or 1mph off. I think the original markings are still there from where we put items on the ground to mark the stopping distances so I'll get by that location again soon and re-measure for myself since I was relying on my neighbor to accurately measure.
#24 ·
Re: Okay.
Neighbours are notoriously unreliable. That's what my neighbour says.;)
