I have a 2005 Boxster. I put an after market HID kit with ballaces.They worked fine until I flashed my car with softtronic. Soon after the lights started to flick then sometimes would not turn on at all. I took the lights out and the bulbs are fine, I'm thinking it's the ballaces. The lights were put in 1.5 year ago by pfaff tunning. ANY ideas what the problem is ???
Thanks
Both sides show the same symptoms? If not, swap a bulb to the other side to narrow the issue down. Probably bad ballasts.
yeah, swap the components (bulb, relay, ballast) one at a time from left to right and see if the problem follows the swap. I would think the issue is unrelated to softronics and is just a coincidence. My experience with aftermarket HID is they don't last much longer than 2 yrs.
Thanks for the input. My lights are still not working and the psm and left signal light are not working. I think it's electrical time to book an appointment.
