I was changing my brake pads out for the first time today and managed to break one of the round pressure plates that attaches to the caliper. It was glued to the OEM pad and when prying loose the center part snapped off (see picture below, with a normal plate and the broken one).
Two questions:
1. Are these plates important? I've seen a few people reference installing pads without them (I think). If it matters, I'm installing Pagid Yellows for the track. I'll probably swap back to OEM later.
2. Assuming the answer to #1 is yes, does anyone have a part number so I can get a replacement?
Thanks!
Discussion Starter #4
Thanks.. should have thought to search for other threads once I figured out the real name of the part. Sounds like I don't need them with the track pads, but may want to get some replacements when I move back to street. Thanks again for the pointer.
I don't use them on my street pads and have no noise issues which is the only real issue. Others have indicated some noise.
Pelican parts also sells the rear dampers in single quantity. My local dealer wasn't able to find a number for them.
Discussion Starter #7
Thanks, I found it on there: 996-352-086-02-M260 (for anyone else who's looking)
