1 - 13 of 13 Posts
just bought a cayman today and tried to set up the homelink did everything by pressing the learn button and the fog lights blinked 3 times but still it doesnt work, ive tried the steps couple times and even tried with different buttons on the homelink, i cleared everthing and tried again but still doesnt work but everytime the fog lights blink three times. am i doing something wrong or maybe just a bad homelink or bad garage door opener, my garage door is 5-7 years old genie. thanks
Super Moderator
Are you sure your garage door opener isn't one that uses a rolling code? If so you may be programming the Homelink correctly, but you just need to get your opener to learn and accept the code the Homelink is putting out.
i pressed the learn button then stood in front of the car to hold the remote and it then blinked 3 times
My Genie is about 3 years old. There's a learn button you need to press on the garage door opener drive unit. On mine, you push a button and a light blinks until you tell the car to learn, then the codes are correlated. Check your door opener owner's manual or get the model number and look up the manual on line to get the right procedure.
You must learn the opener to the car as well as the car to the remote.
However I can get mine to work because of incompatible code protocol even though the remote is on the homelink compatability list.
Using the handy dandy search function by plugging in "homelink" discovered this informative thread.
http://www.planet-9.com/cayman-boxster-chat/1461-homelink-garage-door-opener-help.html
You have the car programed when it blinks 3 times. Now you need to program the car to the genie motor.
Get on a ladder and take the light cover off, you'll see a red led light
Push the button next to it, now this led light will flash
Go back to the car and push the same button in the car you just program 3-4 times slowly
This should work
thanks, guys. You answered a question that's been bugging me since I got my Boxster last April. I followed your instructions and got Homelink to open both my garage doors. Previously it had only worked on one.
wow, was going to look this up and/or ask about this. I spent 30 mins parked in the driveway with my garage going up and down trying to get this to work, and finally said "forget it." I was starting to get looks from the neighbors. Not "that's a cool car" looks, but "what the hell is he doing?" looks.
i'm going to try the advice above as well. after i bought my boxster it took me several tries to get the homelink to work but it finally did. this past summer i replaced the garage door openers and haven't been able to re-activate the homelink no matter how many times i tried. so, i just stuck the remote on my sun visor..... works just fine!
Im gonna try this too. However my garage door openers are like 21 years old. LiftMasters I think. But, I will poke around. We have a 3 car garage and I got it to work on one side but not the other and they are the same openers. Hmm.
1 - 13 of 13 Posts
