1 - 11 of 11 Posts
I was comparing my 2007 Cayman with a buddies 2006 Cayman S. My car seems to be 1.25" lower than his measuring to the bottom edge of the fender vertically at the wheel center. But I can't figure out why. I've checked the shocks and springs (Blue/Yellow) and everything looks stock. I'm not likely to change it, but I am curious.:confused:
Any ideas on what else to check?
Blue shocks probably means you are running bilstein dampers. Blue springs certainly aren't stock a stock setup ;)
Gravity partially lowers my suspension, Eibach took care of the rest. Does not sound like stock at all, Bilsteins sound right. Springs and shocks are black on stock suspension.
Discussion Starter #4
The Blue/Yellow I referred to is painted on the black spring. This matches what the dealer tells me is correct for my car. The shocks are also black.
Discussion Starter #6
Same tire and wheel size? A good equivalency check would be to measure the distance from the ground to the center of hub.
Discussion Starter #8 (Edited)
I'm not sure what he has for wheels (I assume 18"), and I'm running 17". The centre of my wheel is 12.25" from the garage floor. My front tires are correct for the car. The rears are wider (255 vs 235) but the circumference should be correct.
Perhaps I'm looking at this wrong. Maybe his car is high, instead of mine being low. Measuring from the floor, to the bottom edge of the fender, through the centre of the wheel, my fenders are 26.5" front and 27.5" rear. What do yours measure?
Discussion Starter #10
Hmm. I double checked, and the sport suspension was not ordered on the car, and would not have the blue/yellow marking on the spring either.
The mystery continues.
Anybody get a chance to measure their fenders?
1 - 11 of 11 Posts
