In the 981s, it takes a good 10-20 minutes of driving to hit normal operating temp (depending on outside temperature). Just curious how long it takes for the 718 to get warmed up.
To hit 150F+ or closer to 180F, it probably takes a similar amount of time.In the 981s, it takes a good 10-20 minutes of driving to hit normal operating temp (depending on outside temperature). Just curious how long it takes for the 718 to get warmed up.
You also live where it's significantly warmer, so I imagine your ambient engine temperature (and therefore oil) starts out a few degrees higherMy 718 is really quick. A few miles and the oil and water temps are just under 200F.
My coolant gets up to temp in under 5 minutes, the oil maybe another 5 minutes,. Porsche manual does state to not let the car warm up in the driveway. Not only is it not necessary, they say that you should not do it. Engine will get up to temp quicker by normal driving, which is what they recommend. Do not rev the engine (above 3k?) until the oil is up to normal operating temp.Porsche recommends that you just "start and drive" although hard use should wait for some reasonable warm-up.
