Well, the title says it all. Not sure how this is going to play out, but here goes nothing...
The Car:
2011 911 4S, 997.2 PDK, Sport Chrono, 14k miles, 1 previous owner.
History:
Insurance salvage due to fresh water flood (so I was told) Bought out of a New York auction. At time of auction car did not run but some modules were active.
A dealer/broker here in California bought the car and had her shipped here. He had her detailed and then had a few of his "expert" friends attempt to get her running.
They did detail her pretty well, not to Porsche standards but well enough to look more than presentable. Their diagnostic capabilities leave a bit to be desired so that is where we shall begin.
First Impressions:
Paint: All original paint, not a scratch on her, absolutely flawless exterior. No indication of water having been inside the headlight or taillight assemblies.
Interior: No unusual interior odor. My opinion is: no water entered the cabin during the flood. Perhaps after the rains a window was left down and during storage she was exposed to a dusty environment. I state this because she does have dust in unusual places and it is not deposited in a manner consistent with a flood damaged vehicle.
Frunk did take on water, at least 4-inches deep. Brake master cylinder was not submerged. Looks as though the headlight module in the lowest section of the frunk was replaced with a good used one.
Engine: Did not run when she arrived in SoCal. Broker drained the engine oil. Approximately 1 pint of fresh water drained from the sump prior to oil flow. Appears engine was not run with oil in sump. Water was not blended with the oil. Power steering and engine coolant reservoirs have no water. Coolant remains at standard high fill mark. Previous installed a used engine control module (same part number) and engine ran for him. A bit of valve clatter and some uneven injector noise but not unusual for a DI car that has sitting.
Transaxle: I will be draining that today for fluid exchange.
Diagnostic Codes: OH, let's see... about a hundred, no exaggeration there ! Many are probably from the battery going completely dead and then shade tree mechanics unplugging connectors. I'll note all of them and then begin erasing codes in each module, probably two or three rounds of that before we're going to see accurate fault codes.
Next Phase: Reset all the modules with resettable parameters ie window stops, stering angle, throttle learn etc.
Follow along, I'll probably do a video series.
The Car:
History:
First Impressions:
