i race my 06 CS with my local club and the Autocross season is coming to an end. i am looking to do some suspension upgrades but stay in my class. i am using the stock Bilstein shocks/springs. my club uses a points based system and i can upgrade my shocks/struts to single adjustable units for 0 points but i haven't been able to find anything available that will use the stock springs and has a dampening adjustment? there is the Bilstein B6 Performance shock at a reasonable price but don't have any adjustment and are advertised as Heavy Duty when the stock shocks are too stiff. i would like something more compliant.
are the B6 shocks a good upgrade or should i look elsewhere? but where? i would consider the CR strut/spring upgrade from Suncoast but i think that would be considered a race upgrade and put me out of class.
there is a shop that i have talked to about re valving the stock struts but i am skeptical. it is fat cat motorsports in the bay area but it seems like a bunch of hype and i am waiting on pricing.
here is the set up i have at the moment
stock shocks/springs
GT3 front sway on full soft
Tarret rear sway 1 off soft
Quaife LSD
Bridgestone Re71-r tires 245/40/18 front on 8.5" wheel and 265/35/18 rear on 10" wheel i should be upgrading tire size to 255 front and 285 rear but same Re71-r compound
street alignment
i am planning on upgrading to the GT3 lower control arms to get some neg camber which should help a lot but a more compliant suspension would be ideal.
any help would be appreciated
Quaife LSD
street alignment
