cireericd- Rather than worry about rake, I would have your car corner balanced. You will be surprised how much each car is different. The only added components are adjustable down links. Corner balancing is an art within the mechanical components of suspension setups where you add the two opposite cross weights of the vehicle together and "try" to get to 0 difference. This is with the weight of the driver in the seat. What corner balance weight equilivance does is gives you equal turnin left and right, weight transfer across the car and also front to back or back to front. You should read up on this subject as it is involved and time consuming for the alignment technician meaning it's expensive. So, after you get this done, you do not want anyone changing LCA's or other items that could affect the weight distribution on the car. Joshua is an expert on this subject and Ohlin setups.
