I have a 2017 CS with Sport Chrono. When positioned in Normal mode the oil temperature runs about 18-20 degrees higher than in Sport mode. It is very consistent and independent of steady highway driving or suburban stop and go. Flipping the spot mode on always causes a 20 deg. rise and flipping it off causes it to drop back down.
Not sure of the engineering intent behind this. I am guessing sport mode increases flow to the oil cooler for some reason. Maybe the lower temp in sport mode creates greater thermal margin for spirited driving that might be anticipated when it is switched on.
Just a curious engineeer here.
