Hi folks, I did the IDP plenum install today, the install got a little more complicated than I expected, but go there in the end after fighting with the silicon cable for 30mins to install...
Then when I tried to turn the engine, the battery died (Bad Timing) and this threw up a bunch of error codes on the dash. I changed the battery and started the engine.
Now the engine took a few turns of the key to turn over and when it did turn over the first time after the install then I now have a check engine error code and the car is in limp home mode and can not get the car to rev above 2k
The car will idle roughly as still getting used to the plenum install. But I can not drive it as the limp home mode is activated with the check engine warning message.
Any help would be appreciated on next steps to fix ?
Thanks.
Thanks.
