What specifically is the disagreement over the interpretation of 15.5?
I've been running in stock classes for 4 years, but ran in ASP for 9 years before that. Like you, I've long thought that aftermarket adjustable coil-over suspension systems such as Bilstein's to be legal in SP classes, as long as they are not adjustable while the car's in motion.
The disagreement stems from the fact that you can hit the PASM button while on course and that, if you are running aftermarket shocks, this is, according to my club members, in violation of Rule 15.5 which reads:
15.5 SHOCK ABSORBERS
Vehicles may only exceed the allowances of 13.5 as specified herein. . . .
C. Any shock absorbers may be used. . . .
No shock absorber may be
capable of adjustment while the car is in motion, unless fitted as
original equipment. . . ...
We have debated the meaning of "No shock absorber may be capable of adjustment while the car is in motion, unless fitted as original equipment." Does it mean:
1. "unless fitted [with an electronic adjustment] as original equipment";
2. "unless fitted [with electronically adjustable shocks] as original
equipment; or
3. "unless [it is the same electronically adjustable shock] fitted as original
equipment.
If it means 1. or 2., we should be allowed to run aftermarket electronically adjustable shocks because our cars came with the (in cabin) PASM button for changing settings on the optional electronically adjustable shocks as original equipment. If it means 3., we wouldn't be allowed to run anything but the OEM electronically adjustable shocks in Street Prepared.
Remembering that Clause 15.5 opens with the statement that "Any shock absorbers may be used", I have suggest that the later portion of this clause should be interpreted in accordance with 1. or 2. above and, therefore, I should be allowed to change to the Bilstein PSS Damptronics. The Minnesota Autosports Club has disagreed.
