I just installed Victor Zehn wheels (19x9) and Hankook V12 tires (235/35) - fronts. I noticed steering wheel vibration right after install (Roadforce balanced) between speeds of 60-75. I previously had 18's with no issues.
I brought the car in for rebalancing yesterday, and the balancing changed slightly. The vibration is still there (marginally better) now more at 65-75. Below and above those speeds there are no issues. Rock solid at 100. There are times when it's gone, which appears random, not based on driving surface. On the ride this morning it was smooth, and while going through a long turn, the vibration picked up and stayed when straightening. It's almost like they're both off and at times find the "even-out" spot. I'm using stock lugs, 96 pounds torqued.
I've read numerous posts about this slight vibration issue, but wanted to see how common it is (maybe a 19's issue?).
I'm bringing it back this afternoon, and Discount Tire will try to obtain less than 10 pounds Roadforce. I know that a couple of the wheels were already at or below 10 pounds.
