I posed this question on RennList this morning - and no responses yet. Not too surprising since they have 5 different forums all for the same Boxsters/Caymans.. (I have some hope of fixing that - I'm a mod over there..)
Anyway - my glove box handle (the one you pull to unlatch and open it) has quite a bit of play in it - probably about 1/2". If I lock the glove box that play is reduced to a more acceptable 1/4".
Luckily I'm a bit deaf, so if it's making jiggly noises I'm not hearing them, but I'm more concerned with the thing getting infinite play in it - meaning I can't open the glove box.
So here are my questions:
[ ] This is normal - think of something else to obsess over
[ ] This is awful. Your car will blow up soon (or require you to blow it up to get into the glovebox)
[ ] Hey - I had the same issue and this is what I did to fix it:
[ ] Something else - please elucidate
Thanks for your time!
Don,
On my 2010 BS, the glove box latch actually broke. I was able to McGiver a cure, but what I learned was that the parts list drawings have enough info in them to tell you what is going on with the "looseness." I'd recommend you spend some time looking at those before doing any disassembly. PS: If you decide to do some disassembly, be forwarned that there are several springs in the mechanism which WILL scatter parts during disassembly.
Good luck!
Joe Henley
Don,
Good luck!
Joe Henley
Joe - thanks for the reply. Most P dealers on-line no longer offer the high-res parts layout diagrams they used to. Most of them are small images (I suspect all from the same source actually)....
When yours broke - what broke?
And the springs - are they located on the rotating latching mechanism that goes to the two latches on the sides? I did lookup a replacement latch assembly (the handle/lock part) and I assume without a key/lock included (use old one) looked to be around $50 from several dealers. Seems too cheap to be true. 2009 Porsche Boxster Base Convertible Glove Box Handle. Gray - 997552362015V7 | Byers Porsche Parts, Columbus OH
Don,
My guess is that the handle is not your problem; so I'd recommend you not order one just yet.
Attached are two easy items:
My link to RennList parts lists has failed, and the link to Porsche NA isn't showing pictures anymore. Let me see if I can relocate the info on the web, if not I'll copy the relevant info and send to you via here ior e-mail. I'm pressed for time right now, I'll run down the info for you tomorrow.
Joe Henley
Don,
I tracked down the Porsche parts list at:
... go part way down the page and you can select model and year. That gives you a large pdf file; the glove box info is at about page 350-360.
The service manual info -- I can't find it on line anymore. I copied the relevant section, it's about 1.2 MB. I'll try to attach to this note. If not, I can e-mail it to you.
Once you've looked all this stuff over, you'll see that the glove box door is an inner shell and an outer skin. The openner and locking mechanism(s) are sandwiched between the two. It's in there where the levers and springs are. It's where the pins and stops are molded into the inner shell -- and thus where wear on the plastic causes problems like you have.
In my case a pin was completely broken off. I managed to elongate a spring enough to reach a place where I could hook it. It's lasted a couple of years now, so fingers crossed. This is why I recommended you look at this stuff, and remove the gbox door skin to see what's going on in there before you purchase a replacement latch handle. From my experience (all of "once"), it'll probably be something worn out in the mechanism, not the handle. PS: ebay has lots of gbox doors for sale if yours is not repairable (McGiver-able).
OK, now to try to attach the pdf file....
Joe Henley
Discussion Starter #6
Joe, thanks MUCH! The parts diagram still gives little detail on what one might expect to find when splitting the clamshell front cover. Some people have mentioned springs flying around.. :(
AllDataDIY copied the section on the glove compartment that's in the service manual, unfortunately, it's very incomplete. From what you said the plastic mounts and such are molded into the inner shell? That means I don't have to worry about color, which makes getting an eBay one for parts much more feasible. I think I'll take it apart maybe this week since we're supposed to have a storm for a few days...
Thanks again!
Don
Don,
You're welcome. Yes, the pins and bits are molded (mostly) into the inner shell. IIRC, there are a couple of bits molded into the outside shell which "hold" some parts in place on the inner shell; but that's about all.
One use for the parts diagrams is finding where all the screws are. On my 2010 BS, the inner shell had been sprayed with some sort of flocking. It covered up several of the screw heads, making them difficult to find if you don't have a picture.
I mentioned the flying springs from experience. I'm too old to be crawling around on the car floor, looking for scattered parts in the carpeting. Black carpeting + small black parts = ugh! If I had to do it again, I'd line the foot well with an old white sheet.
Have fun this week-end.
Joe
