Just installed a Kenwood double din with Nav. Trying to find out if the car audio is supposed to play when the nav map is showing. Mine will revert to the previously selected input screen. I get turn by turn instructions but no map. Is this right?
My Kenwood DNX 6140 plays while map is on screen.
Instructions will interrupt music.
I have a feeling you need to go into the settings menu to make some adjustments.
BTW, if you find the Nav volume blasts you, the volume settings are hidden in the AUDIO menu settings
The problem was in the head unit. I had to send it back for a replacement. Spent several hours with the folks at Kenwood trying to fix it. Waiting for a replacement.
thanks for the info.
