1 - 20 of 74 Posts
Hello - After years of research and much time on these forums (thanks for all the help!), we ordered our Boxster GTS with a January build. I thought we were done with options, but I had several people locally recommend the 18 way seats over the currently selected 2-way.
I plan to keep this car for a long time. It won't be a daily driver, but I can see long road trips in the future.
Does anyone here have strong opinions one way or the other? I did go back to my dealership last week to do an A/B comparison. Kind of hard to draw a conclusion without really driving a lot of miles in each.
Just wondering if anyone else here struggled with this option and had an opinion to share.
Thanks!
This may sound like motherhood but if you were able to find a comfortable position in the 2-way seats and are a set-it-and-forget-it type, then the 2 way seats is likely all you need. If you like to adjust your seating position for, say, highway cruising or to help deal with back discomfort, the 18-way seats will provide a better range of adjustment. I test drove both and found, after some trial and error, that the 18-way seats were better able to accommodate my gorilla frame (long arms and short legs --- perfect for Fiats...:)). Also, you present yourself as "we" so you are either British royalty or your significant other has been part of the decision making. So if there are two of you that may be driving the car, the 18-way may be the way to go.
BTW, congratulations on finally pulling the trigger.
I struggled with this about 3 months ago when I ordered my car...
In the end, I ended going with the 2-way sports plus because...
(1) I am the only one driving the car
(2) Once I find the ideal position, I never change the settings
(3) It's a "bargain" at only $800 :)
Having taken delivery of the car this past Friday and driven 172 miles on Saturday and 260 miles on Sunday, I can say the 2-way sports plus seat is phenomenal.
It is very supportive in all the right places. Even after driving 3+ hours straight, my back was never sore.
One thing I wish that I gotten is the "easy entry" option, where the seat slides back automatically for ingress/egress.
I think this may be part of the 18-way. Other than this, I really dig the 2-way sports plus. It is very comfortable and supportive.
Thanks!
I struggled with this. It is easy to decide on the seat itself. I set my 2 way seats and they will never move. However, you should ask if you want to packages that only come with the 18 way seats. Keyless entry, LED light package, memory of all car functions from last setting, memory seats, etc. These packages have more features than advertised, lots of little things that add up. I wanted keyless entry and the LED package but stayed with 2 ways as a trade off for Burmester ( worth it to me). Just something to think about, it is not only about the seats.
If you fit in the 2-way seats, and have no need to change seat positions in a hurry, the 2-way ones will save you 60lb the 18 ways one weigh (which is like adding another 7hp).
We need to switch between me and the wife in a hurry, so we went for the ones with the memory (i.e. the 18 way ones).
18 way. I own 14 way seats, and in one year of owning my 981CS, I have changed or tweaked the seating position a dozen times.
Reactions: blackmanx
I love the power/memory seats! I've owned both, the premium package is worth it.
I like the 18 way , being able to adjust the seat on a long trip is nice. The premium package is the only good deal in Porsche's option list.
Definitely recommend the premium package. The seats are so comfortable. I have back pain/sciatica & normally take an Advil before driving any distance. No pain in these seats, even on a 4 hour drive.
If you (or anyone who drives the car is short) and therefore has the seat well forward and up, I'd avoid the Sport seat plus unless it was electric. Getting out with the seat forward and up is difficult unless you can open the door fully - especially so with Sports seat plus. I sometimes have to resort to sliding the seat back with my non-plus seat when space is tight.
There is another feature that the 18 way seats have that is particularly useful called 'Comfort Entry'.
After stopping the vehicle, the steering wheel raises to max and whn you open the door, the seat slide back to the max rear, makes exit and subsequent entry much easier and if you have top down even eaiser, so I installed Smart Top also.
The power lumbar support is great, along with the adjustable thigh support. Seat and side bolster adjustments are only used for Track for me but when you want the seat tighter, they are great. The 18-way seats are one of the 'must' options for me.-Richard
We have the 18 way and love them. We have the memory package and with the 2 keys we can save settings to each key. When I use my key, the mirrors, seats, climate control all go to my settings and same for her with her key.
i also tend to fiddle with seat adjustments occasionally, sometimes on longer trips being able to adjust for comfort easily is a nice feature.
The seats dont make as much of a weight difference as i thought. My 14 cs had the 14ways .My 15 has the two way, the 14 CS weighed 3048lbs the 15 CS weighs 3028. The carrara s wheels on the 15 are 12lbs lighter for the set. That means the total difference in the weight for the power seats is 8lbs. I thought for sure it would be a lot more. I actually thought for sure the 15 would have been less than 3000 lbs. Lighter wheels, seats,and suspension (SS vs PASM) . Only made a 20lb difference??carl
Good advice as long as you are the only driver. In my case my wife occasionally drives my car. My wife is 5' 10", and like most women has very long legs. So 18 way seats were a must because of my wife. I can find the perfect seating position in about 10 seconds. Unfortunately my wife tales a lot longer, and needs lots of seat positions to find the ideal position.
I think that's great, but short people including my wife have complained it doesn't move far enough back. It may only move 2" back, which is all the way it can for me, but there's a lot more space behind my wife it could move into.
Did you really buy a 14 and a 15 where the only difference was the wheels? Wouldn't it have been easier just to buy the wheels?
Yes both 6MTs but the 14 was PASM no SC aor PTV. The 15 is X73, PTV,SC, sport seats plus/manual and the carrara S wheels. More than just "wheels"..carl
The way I looked at it is this: should an 80k car (or 90k if you load up other options) have power seats or manual seats? I striped the options down as far as possible for me, but 18 way was one that stayed on the list......
This may or may not matter depending on your colour choices and budget, but it's worth noting that both of the seat choices for the GTS have silver backs on them, but only the 18-ways can be covered in leather.
1 - 20 of 74 Posts
