1 - 2 of 2 Posts
Hey guys
I hope you’re well?
I have a 2008 cayman which had a dead battery as it was sat for around 6 months. It was jumpstarted and ran ok.
It now is jammed in limp mode and idles extremely rough.
i have 2 fault codes with throttle potentiometers. I replaced the throttle body and the throttle pedal itself but none will clear.
I had the Ecu checked and all came back ok. no other fault codes come up apart from lambdas after about ten minutes.
Are there any common places to check?
possible bad coil pack, if plugs and coil packs have not been changed it is probably due.
1 - 2 of 2 Posts
