Hello everyone. I realize that there are some threads out there somewhere that might have some info on this subject, and I have skimmed through things a bit on that front, but I wanted to gather some knowledgeable opinions for my personal setup and usage situation.
So, I just ordered Ohlins R&T coilovers for my 07 Cayman S. I will be doing the install myself, and then taking it to a pro for a performance alignment. The one change I would like to do myself to avoid the labor costs is the installation of control arm spacers. My car currently has GT3 control arms installed, but set to the factory camber spec for a Cayman S due to a misunderstanding between myself and the installer. I believe it was something under -0.1° if I remember correctly, which seemed extremely low. I would like to get more grip and response out of the front end, and the car has been chewing up the outer edges of my front tires, so I plan to go significantly more aggressive on the front camber. My question would be what you fine folks think might be an appropriate number, so that I might determine which spacers to order for the control arms.
The car will never be track driven, at least not for the foreseeable future, as I can't afford to become addicted to such a drug. It will be aggressively driven on deserted Pennsylvania back roads, which are quite bumpy. Think paved rally stage and you are not far off. It also needs to be at least acceptable in highway driving, as I frequently travel a @200 mile round trip to visit family and friends.
In the past, I have only ever run higher than normal negative camber on one previous car. That car was a 2012 BMW 135i. I initially installed M3 front control arms as a performance upgrade, which added about -0.75° to the front camber, bringing it up to around -1.5° when coupled with pushing the mounts out as far as they would go. This was a massive boost in performance. Maybe the single most transformative mod I have ever done on the aspect it affects. I didn't even know it was possible to get that much of an effect, or I would have done it years ago!
I was quite happy with the results, but eventually needed to make a change in order to accommodate wider front wheels and tires. The 135i came hamstrung with 215 width front tires, and not much space for anything bigger. The addition of Dinan camber plates brought the total camber up to -2.5° and allowed me to tuck 245s inside the front fenders with no rub by pulling the top of the tire in slightly. Honestly I didn't feel that the added camber produced much more of an impact on front end behavior on that car though. There was of course an improvement due to the wider rubber and switch away from run-flats, but not much beyond this that I could appreciate with the way I drive. Even with that much negative camber, the car didn't eat the front tires though, going 7K miles with no noticeable uneven wear.
Taking all that into account, my initial instinct is to go with around -1.5°, as that produced the increased grip and turn in, but might help mitigate long term wear issues. The thing is, I don't know the behavior of this car as well as my BMW with respect to changing camber. Maybe these actually like higher camber numbers? Maybe you don't even need as much? So, what do you setup gurus out there think would be the way to go? Any suggestions on toe settings to complement the camber and avoid wear issues? Anything else I may be missing?
