Awesome, thanks! Btw, is this factory spec alignment?I've got -1.5deg F and -1.9 deg R, with, IIRC, 1/16 toe in the rear. with no wear issues. Zero toe in F.
Neutral handling, no wandering on Interstates and on twistees it turns right now.
Hi lovetoturn - where did you get this numbers from?Those are good numbers from Mike. Doesn't matter what the factory spec is cause their settings will tend to make the car understeer for safety reasons. This is what works at about -1.5 in front and -2.0 in the rear for camber, with toe at 0.0 front and 10-12 minutes in for the rear. Many call this a "sports alignment" which gives the car great balance for more aggressive driving. Good for the street and the track.
Hey guys, should I get the alignment done with the spacers on or off?Those are good numbers from Mike. Doesn't matter what the factory spec is cause their settings will tend to make the car understeer for safety reasons. This is what works at about -1.5 in front and -2.0 in the rear for camber, with toe at 0.0 front and 10-12 minutes in for the rear. Many call this a "sports alignment" which gives the car great balance for more aggressive driving. Good for the street and the track.
It won't matter.Hey guys, should I get the alignment done with the spacers on or off?
I'd like to see a Porsche document, just to be sure. Besides, those alignment specs should be listed like this: -0.70 +/- 0.35, -1.70 +/- 0.35, etc., with the middle number always the target. And yes, the front seems too conservative. Also worth knowing would be what are the alignment limits of the stock X73 suspension, but doubt even Porsche documentation would show that.As per my alignment sheet the X73 specs are as follows where: (' =degrees) and (" = minutes)
Front: CAMBER @ -1'05" to -0'35" TOE @ -02" to -04" Caster @ 7'50" to 8'50"
Rear: CAMBER @ -2'05" to -1'35" TOE @ +03" to +13"
Unless you have GT3 or other non-standard LCA's Caster is not adjustable. I'm at 9.5 caster on both with a track alignment on GT3 LCA's. 7.5 to 8.5 is spec.Guys, what is your CASTER setting? slightly forward? Let me know when you get a second.
That makes sense now. Struts don't have adjustable caster, and even though Porsche doesn't say our cars have struts all around, that's exactly what they have. Thx.Unless you have GT3 or other non-standard LCA's Caster is not adjustable.
Exactly. And OEM GT3 LCA's only allow minimal caster adjustment (eccentric hole or middle hole, so either a lot of caster or near stock), but many track folks run solid thrust bushings which are fully adjustable via a sliding puck. Hence the very high caster on my car.That makes sense now. Struts don't have adjustable caster, and even though Porsche doesn't say our cars have struts all around, that's exactly what they have. Thx.
In theory it shouldn’t for some adjustments, but it does. The geometry is dynamic. Motorsports alignments are also done with hot tire pressure.It won't matter.
Wow. I did find it odd that it seemed like it wasn’t even left to right and a lot of numbers in the red, but didn’t realize it was that bad. There isn’t any sign of damage to the suspension or wheels, that I am sure of. But this alignment is from my Porsche dealership in Los Angeles, if they aren’t qualified I’m not sure who is.Santos, either that shop doesn't know what is doing, or you have suspension damage on your car. The front camber is basically zero on one wheel, and over 1 degree on the other; totally unacceptable. Didn't they tell you??? In addition, those specs don't sound right for any Porsche. Only 0.20º of base camber is for a freaking Buick, not a sports car. Manufacturers prefer understeer, but I don't see how you can have decent handling with anything less than at least half a degree, but more like 0.75 at the very least for an S. Take the car to a reputable shop with Porsche experience, in case you have suspension issues. Good luck.
