1 - 20 of 22 Posts
I'm anal. I'll admit it. I like the center caps aligned with the valve stems. :crazy: But my center caps want to rotate as I drive. Does anyone have a fix?
have you tried putting a bit of tape/masking tape around the "clamp" portion of the centre caps?
i find that giving them a bit of thickness gives the caps of most cars a better fit.
simple and takes only a few mins.
Good suggestions, but you might want to think of this as an opportunity for self-therapy and just go drive.
Absolutely not! We WILL have crest pointing to the valve stem!
I don't even think it is anal. :)
I do drive it. That's how the center cap gets out of line. ;) Besides, detailing the car is my therapy. :eek:
Agree: when I have bigger problems than my anal tendencies, it's nice to have something to go perfecto-mode on.
This has been bugging me for the past year on my Boxster. I align the caps after every car wash, but they get mis-aligned fairly quickly. Such a simple fix, I'll have to give it a try. Thanks for creating the thread!
Just a note on using the silicone RTV to build up and add a little grip. Let it dry before putting the cap back on. The stuff makes pretty good glue too. Might be a headache the next time you get tires.
If this were a true enthusiast forum, like an audiophile forum, somebody would be claiming that they can feel the loose caps compromise their handling at the limits.
How else are we supposed to find the valve stem?
Well, you could put a little dot of neon orange spray paint on the valve step, but that would totally screw up your wheel balance and alignment and unsprung weight, so I guess you're right. I was going to go hit the twisties, but I'll fiddle with my caps for a while instead.
It's kind of funny... this is pretty amusing, but I just realized I totally rate electricians and painters on whether they make the slots in the [screws of the] switch/outlet cover plates line up vertically. Not really a whole lot of difference.
This is something I never thought of until now. So naturally I went out to check mine and after almost 8000 miles all of them are pointed at the valve stems except one which I adjusted. This will be something new for me to keep track of.
Haha, I did the same, checked mine the other day after reading this thread and all crests were pointing at the valve stems. I know I didn't do it and I had the wheels off last year to clean and wax the rims. I did have it at the dealer two weeks ago for a brake fluid. flush, they must have done it.
Discussion Starter #17
I use large, chrome, Phillips-head screws to attach my license plate. All four screws must be pointed the same way (+). :crazy:
Centerlocks would drive you guys batty. The caps fit into the centerlock nuts, and have tabs that line up with corresponding indentations that let you slip a thin slotted screwdriver into to pry off the cap (there is also a "special" tool available). When the locking nut is torqued down, the crest points where it points: there is no way to adjust it. Personally, I have come to appreciate the exquisitely engineered randomness of it all.
Reactions: gfspencer
Discussion Starter #19
Yep, that would drive me nuts. :hilarious:
Suncoast sells valve stem caps with the Porsche logo on them. They are large and easy to spot. I use them. The center caps themselves are made of a flimsy plastic and you can buy a tool (looks like a bent hanger) to pry them off, align them carefully and snap them back in place. I suspect they will loosen up with time, especially if you break one of the tabs.
Gluing them in place is a good idea.
The things we put up with, with these cars. Sigh!
1 - 20 of 22 Posts
