by: Interpol
Description: Hi guys, I just installed aftermarket rims so I no longer need these spacers and bolts. They were on my car for less than 3 months and everything is in great condition. I purchased these spacers and bolts as a set from Maxspeed Motorsports Here's what you get:
- Two 7mm front wheel spacers
- Two 14mm hubcentric rear wheel spacers
- Ten 40mm lug bolts (match with 7mm spacers)
- Ten 45mm lug bolts (match with 14mm spacers)
- Four mounting screws for spacers (these fix the spacers to the hub)
The spacers are made by Maxspeed out of high-quality aluminum. The lug bolts are manufactured in Germany by RAD, are high-quality, Dacromet-coated, and have a ball seat that are 100% compatible with OEM Porsche wheels. The spacers as pictured above are a little dirty but are rust/corrosion free as are the lug bolts. The mounting screws are rusted but functional.
More information can be found here: http://www.maxspeed-motorsports.com/wheelspacers14.html
This set originally cost me $265, so $150 is a steal.
The RAD lug bolts are 17mm and not 19mm like OEM, so I will also throw in a 17mm lug wrench.
$20 shipping to anywhere in the USA. Sorry, I will not ship outside the USA or Canada.
