It's that time again, time for another Mods4Cars group buy on the following products:
- SmartTOP-986
- SmartTOP-996
- SmartTOP-997
- RemoteTOP-996
- RemoteKEY for 997 Coupe, Cayman and Boxster 987
For you - the 997 coupe / convertible owners - thess products are suitable:
RemoteKEY feature overview:
# Remote window control: Easy one-touch comfort operation of windows with the original remote on all models (US and Euro) by holding down the power-locks button. No extra remote fob or reprogramming of the key or car is necessary!
# The "Lock-In" feature locks the doors once the car starts moving. In contrast to the original Porsche feature which can only be enabled or disabled at the dealership, this feature is user-programmable and even better, optionally the doors also unlock when the engine is switched off and the key removed.
# Home light XL: The Headlights can be activated for 30 seconds at any time by tapping the trunk button on the remote twice. Tapping the button twice again before the time runs out will switch the lights off immediately.
# Trunk button delay: Prevents accidental opening of the trunk in most cases. If activated, the trunk can only be opened by holding down the trunk button on the remote for longer.
# Chirp on lock/unlock: If activated, the alarm horn will give brief "chirp"signals when locking/unlocking the car. IMPORTANT: For the chirp feature to work, the factory alarm needs to be present.
# Auto-Tilt function for the passenger-side mirror on reverse gear. A great addition for cars without seat-memory.
# Passenger window auto-up fix for all cars where the window will only roll up automatically once it is past half way. Usually found on 997 Coupes
# User programmable: All features can be individually enabled or disabled. Some also allow different personal preferences to be set. All settings are retained even if the car battery is disconnected.
# Shop/Diagnose mode: The chip can be set to be completely passive, as if it was not installed at all. It becomes "invisible" and will not interfere with any dealer diagnostic tools.
SmartTOP-997 feature overview:
* Comfort soft top control while driving: Within the factory-set speed limit the roof can be operated automatically with a short push of the open or close button. A feature that especially stick-shift drivers greatly appreciate.
* On the Euro-model 997 the smartTOP997 will raise all windows after the top has been closed with the extra soft-top button on the remote.
* Remote top control: Operation of top and windows with the original remote on all models (US and Euro) by holding down the power-locks button. A comfortable one-touch operation can be activated as well. No extra remote fob or reprogramming of the key or car is necessary!
* The “Lock-In” feature locks the doors once the car starts moving. In contrast to the original Porsche feature which can only be enabled or disabled at the dealership, this feature is user-programmable and even better, optionally the doors also unlock when the engine is switched off and the key removed.
* Home light XL: The Headlights can be activated for 30 seconds at any time by tapping the trunk button on the remote twice. Tapping the button twice again before the time runs out will switch the lights off immediately.
* Trunk button delay: Prevents accidental opening of the trunk. If activated, the trunk can only be opened by holding down the trunk button on the remote for 3 seconds.
* Chirp on lock/unlock: If activated, the alarm horn will give brief “chirp” signals when locking/unlocking the car.
* Comfort window control: All windows can be operated with no need to turn the ignition on. In the original condition, the windows are dead before the ignition is turned on and after it is turned off and a door is opened.
* Simplified window operation: The rear windows can be operated without the need to flip the rocker switch, simply by holding the window button after a front window was opened/closed. Holding a button in the 2nd position (one-touch) for 1 sec will automatically operate front and rear window simultaneously.
* User programmable: All features can be individually enabled or disabled. Some also allow different personal preferences to be set. All settings are retained even if the car battery is disconnected.
* Shop/Diagnose mode: If activated the smartTOP is completely passive, as if it was not installed at all. It becomes invisible to diagnostic tools.
The RemoteKEY-997 (for Boxster 987, Cayman and Porsche Carrera Coupe 997) will be shipped using a NEW HARDWARE PLATFORM WITH USB SUPPORT.
Additional features are:
- lifetime updates for free
- no need to return the product
- DIY software updates, using a standard usb cable and a windows pc with internet access
- EASY configuration using a windows pc software
NO PRICE CHANGE - USB SUPPORT INCLUDED FOR FREE!
So who is "IN" on this Group Buy? We need to start a List, please fill in your name here:
http://www.planet-9.com/cayman-boxster-electronics/46756-mods4cars-comfort-controller-group-buy-june-july-2010-all-products.html#post466845
Best regards, Sven
