1 - 12 of 12 Posts
I found a few threads on this, but no clear answer, and need some advice. Just moved to Cal from Florida, which had no emissions testing. In my INFINITE WISDOM, I removed the first set of cats that are inside the header. Have a CEL and code for converter efficiency. I know I can try to buy a set of used headers/cats and resolve the issue.
Does anyone know if any of the O2 sensor extenders, or mini-converters that fit between the sensor and the cable can get the car to pass? I installed a set of simple extenders, but the CEL is staying on, so obviously it doesn't likely clear on it's own. Is it possible I could have someone clear the code and it would stay off, or is my only alternative to replace the headers and get back to stock??
Thanks!!!!!!:helpme:
Discussion Starter · #2 ·
Does anyone have a set of headers/converters they would sell at a reasonable price? I'd RENT them from you, if that works..... :)
lol. Don't think mine are unreasonably priced for relatively low mileage cats based on previous transactions :p
I could absorb part of the shipping if you are willing to wait for 6 to 8 weeks. Let me know via PM if interested. Thanks
Zinger,
I don't think yours are unreasonably priced either. The freight and time is the challenge. Will get back to you on them soon.
Thanks,
Chris
Make sure your smog tech knows to always disable the PSM when the car is on the dyno. And he will have to do it several times since the test involves stopping the car. You'll get a error code otherwise.
Zinger,
Thanks,
Chris
haha cool. Just hoping recover some $$$ out of them and have them out of my tiny apartment. That's all.
Interesting. I always just ignored the error since it goes away after driving. Does a non-PASM car keep the code?
Two of the three errors (ABS, PSM, Check Engine) will clear with some driving.
The check engine needs a tool to be cleared. An active check engine error will auto-fail a smog test btw.
Discussion Starter · #10 ·
Thanks to all for the input, and thanks to Zinger for great deal on the headers and cats. I installed them and the engine light went off after 2 days. I passed the smog test yesterday, with a recorded CEL, but no active CEL.
THANKS!!!!
With the two SMOG I've done, I only got PASM fault/ABS. Both cleared without a tool and 2-3 min of driving. (Didn't see a PSM fault, only PASM)
THANKS!!!!
Congrats! Good stuff then. You could always swap back to the aftermarket cats after inspection hehehehe
these are ultralow mileage cats anyway. Seems like they only have 10,000miles on them. Previous owner seemed to have taken the cats out when the car's pretty new ...
1 - 12 of 12 Posts
